1 - 11 of 11 Posts
Does anyone know if you can take the bushings/seals off of the valve cover bolts or how to do it? This is for an OBD1 SOHC Z6. I have new seals but I can't see how its possible to change them.
I believe so. The seals are on the bolts and there is a lip on the bolts. I dont see how the metal piece on top of them would ever make it over that lip.
thank you very much. i already had the rest done. the bolt thing helped a bunch.
/thread
some of the most simple things, are things we never deal with.
that being said, sometimes we overlook the simplest answers for them as well.
thanks for the input.
i did all mine in 3 minutes. not sure why everyone thinks they are a pain. and yes. 3 minutes, i counted.
i pulled the rubber seal apart from the metal washer for the top with my finger nails and cut the rubber off with scissors and then hit the new ones on with a hammer and socket. it was quite simple actually. i figured why try to pull them over the hump when i obviously dont need them anymore... so why not cut them?
1 - 11 of 11 Posts
