1 - 20 of 63 Posts
It's best to order a Z6 headgasket even for an A6 engine?
sorry for noob question, but I have gotten mixed info...
1991 Rover 216 GTI .
If your going with metal gasket,I would deck the block,Ive had 2 fail ,one on a A6 other on ZC,both skimmed not decked,both failed around top of sleeve,put normal gasket back in both,3000 miles no probs.Metal gasket failed by 500.both engines about 100000 miles on them.
Iv'e got a spare DOHC ZC engine ill deck and skim that and see how much longer that lasts.
93 Legend L Coupe.
MLS>graphite in almost every case. I generally still coat headgaskets with copper dressing to help sure that they seal on less than perfect surfaces and hopefullyprevent the gasket from sticking to the head or block, thus allowing you to reuse the gasket, if you want.
Massive assumption,I am quite methodical in my work,and followed correct procedure.
no, actually its not. why? cause many people have been using them. honda even suggests them for the a6.
possible reasons why yours failed:
  • warped the head during tq'ing
  • incorrect tq spec for a MLS HG
  • incorrect tq step
  • bad tq wrench spec
There isn't even a consensus on this board about whether or not you should use a d-series engine!
correct! i would bet almost half the "active" (the "die hards") members of the board don't even have their d-s anymore.
90 CRX Si
depends where you want your compression. if you want it stock, get a Cometic MLS the same thickness as the a6. if you dont care about a .1 or .2 bump, run the z6...its cheaper
x2. The 2 Z6 ones i've used haven't been composite, AFAIK only the old A6 ones were composite, but I think now all hg from Honda are not composite (at least on a D)
.1 or .2 on a otherwise stock car is unnoticeable and completely safe right?
ps...everyone reped in this thread, thanks for all the input guys!
^ should be but don't hold me for it. With my Y8 I took the middle layer and it's suppose to raise compression. I can't really tell a difference because my motor before was crap.
1 - 20 of 63 Posts
