1 - 20 of 20 Posts
Honda
im buying a walbro 255lph.....im keeping the stock rail
do i need an aftermarket fpr?
its for a 300whp turbo build.....not the one in my sig
thanks
Honda
can you explain further.
ive seen tons of turbo setups here on d-series, and most of them have no aftermarket fpr's on them.
yet some say you definately need them.
thanks
Ranger - work truck
an fpr is a band aid for bad/lazy tuning..... ie rather that adjusting fuel pulse rate/duration and injector duty cycle, they might raise the psi one or two pounds and get ''close enough''
Actually that's not entirely true, what if he ends up with to high of fuel pressure and needs to bring it down? I'd at least put a guage on it after you install the pump to see what your pressure is at. To high and the injectors will spray way to much fuel.
GL man... i never use em, but ive never had a bigger pump besides our drag car... im sure after all this u will know what u need to do, i ohnestly wouldnt worry about one as of right now i were u...
Honda
With a 255lph you can only get so low in pressure. The lowest i could get mine was 44psi with the vacumme on. I dont think you need that big of a fuel pump for your setup if its what is in your sig.
im in the process of building a 300+whp turbo z6
i guess i need to say that in my sig......my bad
EX coupe
if you are building a 300WHP car....then a FPR isnt a bad idea now is it?
Honda
well, thats kind of the purpose of this thread.
ill tell you the answer after i get a few more replies on peoples expiriences
Honda
wow.. i ddnt know u were talking about a future setup B MORE CLEAR! ROFL!
yeah i should probably change the original post and say its for a 300whp turbo build
my bad
well I got one.... just so its easier for me tuner to tune my setup... hell you can get em pretty cheap off ebay.... if you really wanted one...
Worst Mechanic Ever!
EG
yellow bar for me
viper blue 92 eg
i am running an AEM on my car. it serves two things to me.
1: eye candy
2: when i am nearing the max point on my 440s. ill bump up the pressure and get a few more horses out of them. then ill upgrade injectors.
96dx saloon
i was just showing him that there are cheap ones. i personally have an aem. i think it is worth spending the extra money on this type of part. and you are right haysoos, it might be cheap now but could cost you a lot more down the road. do it right the first time.
1 - 20 of 20 Posts
