hi im still very new to rebuilding my first motor.
i want to know that do i have to remove the flywheel to remove the crankshaft?
my crankshaft keyway is damaged and i need to get that checked so as everything else.
i cant remove the flywheel bolts, with hand tools. hard enough the crank bolt breaks loose. and also i dont have a air compressor at my home. my other option is bringing it to work but i dont want to put the whole block in my car. its oily
is it possible to remove whole crankshaft with the flywheel on?
if its possible id rather bring the whole crank w/flywheel to get it off.
