1 - 13 of 13 Posts
can some one please help me with my problem, when i bought this I was told it's for an obd1 single cam vtec but at any time only 2 of the 3 bolts will line up. please help asap, I want to get this swap in and running asap. this distributor is also going on a d16z6 head, Also if I bolt up the 2 parts that will bolt up, whats the worst that could happen? besides some leaking
HONDA
it is an odb1 but not for sohc vtec... BRB ill go take pics of what you need to do
HONDA
OK you could have seached it.. but i want to show off my handy work.
all you need to do is open up the top hole a bit and then cut the one side. the use big washes.
see pic below.
well the guy I bought it off of told me that it was for an obd1 single cam vtec, I guess I was lied to. but can I still use it for vtec?
oh and also are you running all 3 bolts on yours or just the bored out one and the broken one?
so...even though it's a non vtec dizzy, would I still be able to achieve vtec with it? And I plan on buying a new one (the right one) once I get the funds up and after the swap is in
HONDA
just the 2 points used for mounting but that is fine....
1 - 13 of 13 Posts
