1 - 1 of 1 Posts
I have a 1997 integra
I'm planning a mini-me on my sohc zc using a JDM d15b vti cylinder head
The zc dizzy is a 7 wire mitsubishi unit - all the wires on the connector are in a line, not side by side (two bollts holding it in place)
I'll think i'll be using a p08 ecu
Now, the problem is that i'm told that if i use a p08 (or any vtec ecu) i need to use the 9 wire dizzy off the JDM d15b because the zc dizzy has no wires for the rpm signal.
I don't mind wiring up the 9 wire dizzy but i can find any info on the 7 wire dizzy so i don't know what wires go where
Any help would be great, thanks :)
1 - 1 of 1 Posts
