1 - 20 of 46 Posts
Well I was sick and tired of having these faded ugly wiper arms on the ITR so I decided to refinish them. Previous owner was SOOOO JDM west coast style that they were not used.
Here is a write up of what I did:
-Removed wiper arms- 14mm
the OEM finish was done
-Sand down the arms to bare metal, but dont forget hinge the arm and sand in the joint space also.
-Clean off the sanded arms: use a tack cloth or something that will remove the dust from sanding.
- I hung each wiper blade from a saw horse using thin metal wire and primered them. There is no real way to go about painting them while laying on a surface so I would strongly suggest hanging them in a similar fashion. Do each arm individually.
-Post primer I painted them using Duplicolor High Performance Wheel coating in Flat Black.
-After allowing it to dry enough to handle I removed each from the wire and gave the spot the wire touching a quick touch up blast of black.
-This how they look after completion:
I pitted the newly refinished wiper arms against the bug sponge yesterday and they held up just fine
ministry of mayhem!
93 honda integra
i did the same to me DA.
nice write-up. :TU:
Defender of the D
nice write up.. may i suggest some clear or something to seal it with??
Thanks for the nice comments...
I dont see any need for clear. I chose the wheel paint because it gives a nice durable finish that is rock chip/heat resistance and similar to OEM color.
^Thanks!
I now have a can of the same stuff.. I really like the SEM trim paint., it worked well on my comptech lip. but its pricey
I have no complaints for how I did it, but when I redo the ones on my accord or GSR I will be using the trim paint to see the difference.
BMX bike
wrinkle red would be the sooper-JDM way to do it ! :)
86 MR2
nice!!!
gotta do this now on my faded ed's wipers teh paints 20yrs old and getting flakey
Same as above
if you ever spray new plastic make sure to scruff it first then lay down a coat of plastic adhesive promoter. SEM and a few other companies make it. our sibling shop sprayed a bumper without taking this step and you could peel the paint off like paper. mold release does not like paint eiter
1 - 20 of 46 Posts
