1 - 15 of 15 Posts
Never finishes (TWSS)
91 Civic SI hb
Im looking into this, im thinking of getting a few of them. Any one try it before. Seems pretty easy to setup and alot cheaper then any "brandname stuff" as with all diy electronics. althouh it may be cheaper and easier to use a multiplexer with an 8 chanel AD converter and program the off sets using a andruino. any one into this stuff APSX D1-DIY Wideband Controller Board Module
91 Civic SI hb
Ok thanks for the link i may jus go with my ardunios, and 10bit 8 channel AD converter i have for other projects. that way its a hell of a lot cheaper and i can use 4 wide bands and 4 ect sensors and cycle theouh each sensor a few times a second and setup the refresh rate to close to 4 points a second for logging and 2 points a second for the gauges.
wideband seems like a bad thing to cheap out on in my opinion...
perfectly understandable.
However, a slow sloppy wideband is probably far faster than a perfectly working narrowband style sensor.
Me personally, Ill just force myself to budget around $200 minimum for a wideband setup. But part of that budget is having an extra sensor for testing for problems if they arise
91 Civic SI hb
where do you get the idea of being cheap comes from, have a low cost yes, but being cheap or getting a cheaper product in the end not so much.
any of these wide band controllers have at max 18$ in parts in them, im sure you dont know how cheap you can but electronic components for when you get into actually building things. the labor is what you are paying for. and r&d, not nowadays with programmable micro controllers for like 6$ you have noooo clue of how easy things are.
im not talking about making my own sensors, they are cheap as they are and work very well. and i doubt i could do a better job, but to take a voltage and convert to to digi and display/log the data is simple. you just need to know programing and electrical know how.
instead of using this one as posed in the first link since it seems to not be very good at what it does, since it tries to do it without a programmable micro controller can cause issues. but being able to code it your self for the off sets and turning on and off their heaters and doing things based off other inputs, like idleing for more then x time turn heater on.
companies know this and charge a lot since there are limited people doing it, its the same as anything though, they have to pay for tooling and location and all that so they have to charge more then you doing it by your self.
https://en.wikipedia.org/wiki/Arduino
http://www.ti.com/lit/ds/symlink/adc0808.pdf
'06 3500 Duramaxipad
I understand that the parts inside are cheap. I know that most of the cost associated with these and many other electronic components is labor. I guess what I'm saying is personally I'd rather pay more for something like a wideband from a reputable company because I know that I can trust it. Especially when I have as much into the motor I'm building as I do.
I suppose it would be cool to build your own just to say you did it, but I wouldn't trust it to be as reliable if nothing else as I would a UEGO, LC-2 etc. Plus if it does fail I'll have a scapegoat that isn't myself. :D
91 Civic SI hb
I trust my self over others, so thats why i build my motors and alot of stuff that goes on/in them. my sig use to have my.builds in it. trust me man, i build shit and have lots into it too. some tikes your better of dojng things your self so in the end you have exactly what you want. i also built my own rods and pistons and full custom itbs with only useing premade bolts. thouh so a wide band doesnt scare me.
Pricing is always going to be higher if you dont wnat to build it.
Look at computers. Some people pay 4-5 GRAND for a top of the line gaming computer when its realistically only 1200 in parts. thats what, just under 25 % of price being effective?
1 - 15 of 15 Posts
