1 - 20 of 32 Posts
Ms. Daisy
Make a wall light out of your old head/taillights. :bigok:
Only slightly pertains to cars but something I just did while I was bored.
You will need:
Head/Taillights
12V AC adapter
Extra Wire (possibly)
Wire cutters/strippers
Electrical Tape
Wire Connecters
Take your lights and cut the clips off the wires
Then cut the end off the adapter
Connect the wires from the adapter to the lights.
Make sure you keep hot with hot and ground with ground.
If you want you can splice an on/off switch into the wire. I didnt only because I didnt have one laying around.
Make sure the connections are tight and electrical tape them up.
Plug it in and there you have it! Youve got yourself one badass wall light.
Ms. Daisy
Poop Sock
wrx & slut rex
you could do some brake lights to give off that red light and put them in the bedroom behind the tv or something and get bow chicka wow wow (preferably with someone else, not hand)
and THAT my friend is the only way i could see brake lights getting you laid.
Ms. Daisy
me likes...i'll jus have to do this to a set of ej1 tails...:D
Thanks. :)
If you do try it, lemme know how it turns out. :bigok:
I did my third brake light too. I'll get a pic when I go to my garage tomorrow.
Ms. Daisy
Discussion Starter #19 (Edited)
Wow that looks kinda cool. I might do soemthign liek that in my work bench in the garage, if i ever clean off all the car parts to get to it that is.....
1 - 20 of 32 Posts
