For those of you who are wanting to vent your valve cover.Here are the steps.
I know 10secrex Did a DIY for this but I did mine a little different.
Stuff you need:
2 fittings(got mine at advanced)
JB Weld
Drill and bits
Tap set
Bolts(I used 5/16 allen head)
Locktight
Step 1
Remove the valve cover and drill out the rivets holding the baffle on the inside of the valve cover.Clean Shavings off of surface.
Step 2
Remove the valve cover baffle and designate your points for drilling. Drill your 2 holes for your fittings and press them in. Clean surface
Step 3
Mix your jb weld and apply it to the back side of the fittings. Ensure that they are covered completely around. You can also apply it to the outside but it is not necessary.
Stuff you need:
JB Weld
Drill and bits
Tap set
Locktight
Step 1
Step 2
Step 3
