Well this is my first write up, and i know this is a pretty easy thing to do but i wanted to do some sort of write up, lmk what you think of it.
Tools needed:
Phillips head screwdriver
first, remove the 2 screws (or in my case one screw and one zip-tie) to remove the cover
heres with the cover removed
remove the 4 screws holding the foglight to the mount (they're the bigger, more flat ones)
then, unplug the light from the harness and the light is free!
take out the remaining screws to disassemble the front part of the light
next, turn the light up and remove the 3 screws on the bottom
then you may have to pry the 2 parts apart or they may just pull apart
here is what it should look like
take the screw out holding the ground on and loosen the one on the far side that holds the wire that holds the bulb
now pull the bulb out
slide the white piece up and unplug the bulb
now get your new bulb
plug it in and slide the white piece back over it
reassemble the bulb in the light, make sure the wire is tight and it is hooked under the little metal piece for the ground
now reassemble and reinstall the light and you're done!
great write up! will help out peps I'm sure. i was in the dark when i had had to change mine out. I couldn't believe how many screws were on one once i got my cover off lol
thanks! thats how i felt when i went to do my first one, so when i did the second i made a write up for it
Pew Pew!
EJ6
Holy shit. Fog lights for the 92-95 Models take that much work? LOL Glad I can just unhook mine just like the headlights on my 98 fogs =)
Rep for a DIY though :TU:
