41 - 60 of 67 Posts
my eg8 daily
Thanx Hondadog....
heres some shots of the combustion chamber work I started
what kind of valves are those??!! mine dont look anything like it, and it looks like a y8 head
my eg8 daily
their stock y8...though I'm contemplating going 1mm oversize....prolly not though
...I noticed new oem valves don't have the built up deposits on the exhaust valves, so I polished it off...maybe I'll have them coated when I'm finished to help combat heat
heres a couple of shats of the y8 and z6 in comparison..
i dunno man, my stock y8 valves have the number 12 buldged in the center of the intake valves and i belive an 8 on the exhaust valves, while you have the little circles in the center..
weird.
my eg8 daily
well I think it's a EDM head...I got it from Tank....ask him
my eg8 daily
Well I only got a couple of hours to spend on the head this weekend....got 2 intake and 2 exh ports prepped and a total of 3 comb chambers....of note the deposits on some of the exh valves is very thick....I'm including a pic with a shot of a clean exh valve an one with deposits I buffed them both to show the contrast in color....
my eg8 daily
finished the head today....ready for machine shop!...I'm gonna have 3 angle valve job and the head decked only what it needs to be true....I also micro-polished the cam bearing surface as well as the openings for the rocker shafts
my eg8 daily
okay..besides the dremel w/ flex shaft...heres what I used to get my head looking this way...I spent a total of $28 on everything I had to buy...already had the dremel and flex shaft,and valve spring compressor...of note...DO NOT BUY THIS SPRING COMPRESSOR...it's a pain in the ass to use on a honda head!
Discussion Starter #49
Great pics of the incredible work you have done. Im impressed.When I finish up work on my y7 head Ill post them. You gotta love the intake ports and the job you did on the splitters.
how is a dremmel not powerfull enough? what kind of dremel do u have?
plus your not supposed to grind the snot out of it but take your time..., and you dont even need that powerful of a tool for that, this is aluminum after all.
my eg8 daily
T.Y.:beer: yet, tactfully done....
Wow looks like you did a good job!!! Congrats, now lets see if it puts down more power when you get it back from the shop...
D
All i am saying is that all of the performance shops ive been to dont use a dremel to port. They use something with a lil more power. You can go slower with a bigger bit and take a lot more out than you can going faster with a smaller bit. plus since the other tool's bits are larger, its easier to make the curves and such in the ports.
But if you have a dremel and it works, why buy something else...
Discussion Starter #55
Well, not many of us have the same budget as a "performance shop". And, if you look at the pics a dremel will work just as well. Most of us work out of our own garages.
civic
great photos , do any of you use a normal power drill with a flex shaft ? or do you find it a bit harsh ? i have to say i find this very inspiering , also what compound do you use to recut your valves in to the seats ? as i have never done any alloy head work hahahah i was still in the 1950s untill i got my honda
my eg8 daily
First, where'd that post go?
Okay, I'm only saying this once, and I'm not saying to hurt ANY egos....give a monkey an air powered porting tool and a head and you will get a "ported" head, maybe not what you need...but a "ported" head none-the-less...
HA...
wait i dotn get it?
all i know is that my dremel spinning at 35000 RPM is a little too ruff, i was screwing around with some metal parts when i got it and that thing DIGS IN, i went cheap and got the "on or off" one with no speeds, so i need to dig out a transformer that my buddy has so i can adjust the speed :) haahha, suckers.
but yeah... what ever tickless your pickle right?
my eg8 daily
it'd be nice to have a foot operated speed control...like they use for a sewing machine
41 - 60 of 67 Posts
