1 - 20 of 101 Posts
ed7
1. wrap the hood in some plastic cloth or some transparent nylon x3 or 4
This is weary important because if the resin gets to your hood it will wrinkle immediately
2. Spray the nylon with some wax or some grease
3.Take 1 piece of cloth (not like this :pinch:) and cover it over the hood
4.Mix the Resin / Hardener
5. Tap that over the cloth
6. Put fiberglass cloth for the 2 layer and tap it with resin
ed7
7.Put some net or something in the 2 layer and fiberglass cloth over it for 3 layer
8. Let it dry for a day or more...
tomorrow....
9. Make some paper model over the real hood and trim the edges
Defender of the D
THat looks good.. i wish i was good with fibrglass like that.. my only concern is attachment.. how are you going to secure it with the latch? if at all.. i'd hate to see a hood coming flying into my windshield running down the strip.
ed7
we already drilled the holes at oem brackets. Were just gonna use longer struts and bolt it down (that's 4 bolts on each side near windshield) and pins in front...
It should be enough...anyway its gonna be tested this week....
Lurking... ಠ_ಠ In Your Thread
ES1 Civic
I like this....
I see a lucrative business venture for you amongst the DSO community.
ed7
nice! i bet the garage smelt goooooooooood :)
I slept like a baby :fruit:
The piece we trimmed for the intake is soft, it depends on the cloth you use...
SO cloth is maybe good as 1 layer but no more...
Defender of the D
I wish I understood what that meant.. but idk jack shit about fiberglass.
ES1 Civic
ed7
Discussion Starter #19
the material we used on the scoop(old shirt) turned out too soft...
So its better to use more Fiberglas cloth(comes in the set) and net ....we need to add 1 extra layer ...
And for the record this is our first try with this, its interesting and easy....
98 dx sedan
What kind of "net" are you talkin about??
I got two hoods already, but I'm re-painting the car as soon as its warm enough so this would be sweet to do in the mean time!! :bigok: awesome job!
1 - 20 of 101 Posts
