1 - 20 of 34 Posts
wheres my money man!!
lol was really bored today lol
anyways this is just a proto type lol
can with lid cut off, lawn mower batter, and a motor from something that spins really fast, this is from a toy that launched good size kids cars like huge hotwheels lol
kinda hard to see here but there is crazy movement in the can, at first i had a gear on there but it was so active is shot the fluid everywhere lol so i took it off and it calmed down alot.
still shot here
and video lol
inside the can is the carb from my weedeater.
also idk what it was but some red fluid apperard in the bottom of the can lol no idea what it is, but the pop was a clear one so who knows, kinda like oil, cause it wont mix with the gas?????? odd any ideas
YouTube - 000_0974.MOV
huh?
ahahahahaha......do it.
dude, that could potentially be THEE single, most worst idea in the entire world aside from Marie Curie and curiosity in those "glowing rocks".
but...... being from the school of thought that dumb ideas make for the best entertainment, i say.....
Fu*k the Sh!t out of that can of disaster!
huh?
personally i like jagged edges. lol
Have you used it yet? or just running it?
huh?
i saw the vid, but didnt know you had used it on anything. cool!
you should put an offset weight on the motor
i had one one it was way to much movement in the can fluid went everywhere at the start up lol.
but i might make a 1/4 wheel for it. need to find my keyhole saw lol
get a bigger can, then you can put bigger stuff in there.
Like a paint can, maybe with an extender rim to prevent spillage.
ya i plan to, this was on the wim idea lol
ill see what i can come up with
1988 Honda CRX
I must say, not a bad idea in principle, but the potential for personal injury seems to high.
An old pot of suitable size without needing to be cut, with 3 or 4 decent tabs attached then a STABLE frame with matching tabs, then some old valve springs held between the tabs so the springs act as a suspension. Old valve springretainers welded to the tabs would locate the springs.
A deliberately out of balance electric motor bolted very securely to base and you have a safe reliable useful device if you choose components wisely and build it properly
Defender of the D
What are these tabs you speak of?
1988 Honda CRX
Something to bolt the springs to.
95 CX Hatch
Pat have you ever REALLY wrenched on anything? Most your posts come across as this over scientific book smart bench racer. Just sayin lol...
1988 Honda CRX
I have really wrenched on things starting from probably before you where born, from building billycarts to building a racing bicycle from basic parts, to radically modified street cars to race cars and boats.
I have designed and built machines and had patents issued in my name.
I am currently making from steel bars and discs, a new crankshaft for a 1912 model car I have.
I normally surface grind my own heads in a friends tool room.
I have machined piston tops to correct deck clearance or piston to valve clearance.
I have machined my own light weight flywheels.
I port my own heads.
I have modified engines for extra large bore and stroke and done much of the grinding and milling and some of the other machine work to get clearance for crank and rods and cam lobes in pushrod V8s..
I do my own welding.
Several of my previous jobs involved visiting OEM engineers in many fields to consult on design of products, varying from inlet manifolds to electric kettles and all things in between.
I have helped design and build a vibro polishing machine that has been used for the last 10 years to polish ceramic coated exhaust systems as well as other large coated parts.
The vibro polisher used a spring suspension system similar to what I described above.
I have designed and built a number of trailers for boats and cars and camping.
I am currently helping design some armour for safety gloves. As I have signed a Non Disclosure agreement I can't say more on that.
I Am currently consulting on upgrading a plastics compounding plant to manufacture to Theraputic Goods Association quality materials.
I have built engines for class winning 7 second street cars.
I am currently working on another one that is a 450 cubic inch Ford Windsor based engine. Right now we are trying to see if we can get a 0.800" cam to fit without hitting the crank and ithout coil bind with 350# on the seat springs.
I have built engines for winning speedway midgets.
I have built engines and ancillaries for class winning off road buggies.
I have built engines for top winning touring cars.
I could go on
1 - 20 of 34 Posts
