1 - 16 of 16 Posts
So i thought i would do my own little writeup on this....
For starters, here are the basic items that you will need...
-Paint
-Painters Tape
-Screw drivers
-Lacquer thinner
-Paper towels
Make sure you tape EVERYTHING up, ensuring that you get close to the needles.
I used the paper towels to cover the needles that stuck out on the speedo and tach.
I gave them 2 good coats
Here is the finished product
Before..
After......
LESSON LEARNED!!!!
make sure you cover the back of the gauges, i had overspray.
ENJOY!
So i had the cluster back apard because my speedo was not working and i replaced it with another one. While i had it apart i figured i would see what i could do to brighten it up some. So i took all of the blue covers off of the bulbs that are in the back of the cluster and i also took the light cover off that is along the top on the inside......
I just took it off with a box cutter, so i would not damage it unless i had to.
So here is what it looks like now. I like!
1 - 16 of 16 Posts
