1 - 20 of 26 Posts
Hey just did my obd0 to obd1 conversion and thought that i should tell how easy it was to do!
Part list
-Obd1 ecu plugs-make sure to cut like 7inches of wire on the plugs (i went to the junk yard)
-Obd0 ecu (use pm5,pm9 something dpfi)
-obd1 dizzy (i got d15b7 on my y8 head)
-soldering iron(with solder and paste)
- use google to get the pin outs to the plugs
1. Get a obd0 ecu i used a pm9 use a dpfi ecu they suck ass.
2. Take a torch to the ecu board to remove the plugs {just melt the solder on the pins to the plug} its very easy
3.solderthe wires were they go
Obd1 on the left
Obd0 on the right
A1-a1
A2-a7
A3-a3
A4-add vtec solenoid if got vtec
A5-a5
A6-add o2 wire black one under white
A7-a12
A9-a11
A12-b4
A13-b6
A15-b3
A16-b5
A20-a6
A21-b15
A23-a2
A24-a4
A25-a13 splice w/o2 wire black under green
A26-a18
B1-a15
B2-a16
B5-b8
B9-b13
B10-b16
B11-b10
B12-b12
B13-c3
B14-c4
B15-c1
B16-c2
D1-b1
D2-c10
D3-add knock sensor
D4-toggle switch with ground
D6-vtec pressure switch
D9-b14
D10-b19
D11-c7
D13-c6
D14-c16 splice with o2 wire white
D15-c5
D17-c11
D19-c15
D20-c13
D21-c14
D22-c12 splice with o2 wire green
Thats about it jus becareful when soldering not to solder any of them togetther. My car work fine obd1 and i did the conversion myself. And make sure u use a obd1 dizzy it wont run. Later.
Its even easier to just hack off the OBD0 plugs, and solder on OBD1 plugs. I did exactly what you did years ago, and decided that it would never need to be OBD0 again. So I cut the OBD0 plug out, and soldered the OBD1 plugs in permanently.
I also noticed, after bending and moving the OBD0 pins that stuck out of the original ECU sockets, they started to break.
Ill see about pics im on a g1 so idont know how to yet. But i jus might make a nother one and take pics along the way. And i didnt break any of them lol
I didnt break any initially. Im talking after like 3 years of use, and plugging and unplugging the ECU, they will eventially break...
But dont listen to me... I only did this same thing years and years ago.
Dont worry i was thinking about that but i just leave the harness in and jus unplug the ecu and if u cut the wire down there it jus a pain to be down there for a hour or so jus easyer to do it out of the car and if you notice you dont us all the wires it will jus look messy but i do understaind were u are come from
89 Civic Hatch DX
I agree, I switched over my car from obd0 dpfi to obd1 mpfi last year when I did my mini-me swap. Took awhile cutting, soldering, and heat shink tubing, but I thought it would be worth it since you get a solid connection with soldering. I used this site SolBlu's Helpful Del Sol Site in the how to section to do my swap and also a couple of factory wiring diagrams. I went to a junkyard and grabbed an extra plug for the engine bay for my extra wires.
I did it like this cause I have seen a lit if jumper harness fail..
08 ZX10
I need pics plz!!! I'm in the middle of converting to OBD1 and I'm clueless without step by step pics to compare to what I'm doing lol...
92 Civic Seadan
so what he is doing it pretty much making a jumper harness?
is a jumper harness the easier way to go for someone that isn't good at wires and shit lol
yes a jumper harness is the easy way to go for some one thats not good with wiring as its a plug and play thing...
1 - 20 of 26 Posts
