1 - 19 of 19 Posts
I got the idea from Pata to do a quick DIY on installing your tires on to your rims.
so with newly painted rims I suggest to pop in new tire valves as you don't want future leaks or problems after installing them.
assuming the wheels are all clean, crack free, and ready to mount on new tires.
place the wheel onto the table, secure the wheel on the tire machine by pressing on the wheel locking pedal.
then adjust the installation/removal arm so not to scratch or dig into your freshly paint wheel.
I removed the new tires from my set of BBS wheels as I plan to go with different rubbers on those wheels.
Take some tire lube and lube the inner bead rings of the tires, this will ease installation.
place the tire inside the arm and make sure you got the inside bead of the tire in the lowest part of the wheel, then press on the clockwise rotation pedal, until the whole tire revolves into the wheel.
next the outer tire bead is a bit harder but today's tire machine have a hydraulic press to push the tire bead into the lowest point of the wheel.
press on the clockwise rotation pedal until it goes in.
now you need to inflate the tire and set the tire beads, i set the bead with no more than 40 psi, then install the valve stem inside and inflate to your proper tire pressure.
then it is time to get the tire balanced.
purple wheel on the floor.
my bbs where the new donor tires are coming from.
that is me giving you guys the peace sign, lol!
with the tire valve stem removed i set the bead using no more than 40psi, going higher may result in injury.
me giving you all the peace sign after bead and pressure is set.
Never finishes (TWSS)
91 Civic SI hb
OMG STICKERS. and a type r..... kewl
nice diy though guy. rims look nice
good thing its not your car or you would need a username lol
thanks for the thumbs up, the DIY was inspired by Pata as I did not want some ass to scuff up the wheels.
98 dx sedan
gayyyyyyyyyyyyyyyyyyyyyyy
I was hoping this was a DIY in the sense that I could do it with a hammer in my back yard lol
Any chance you could do a DIY on getting the tires OFF? :D
08 H-D Ultra Classic
Dam that's a lot of stickers and I thought I was bad!!!
LOL
My civic
Somebody loves NFS. Also, not a legit type-r. No 5 lug =)
1 - 19 of 19 Posts
