This DIY is about cheap and effective way to brighten up and change color of your EG Civic or any other car heater control or instrument cluster. Basically LED light and color change in car instrument clusters. Hope that someone will find it useful!
Tools/parts needed:
- soldering tool
- self adhesive led strip (output color choice is yours), I used high lumen output SMD5050 with 60led per meter
- transparent self adhesive film (color choice is yours)
- 2 blade spade terminal connectors (~2,8mm width)
- self adhesive aluminum tape (optional)
- patience
I used 15cm long self adhesive led strip (bright white) and placed it right here for clean installation. I also added self adhesive tape to reflect some of the light, but this is optional.
Then soldered positive and negative wires and crimped the ends to blade spade terminal connectors (~2,5mm width) which could be easily attached to original bulb socket.
This is the final result! Much better than it is with small oem bulbs.
If you want something different, then there's easy and cheap way to customise colors of any of your clusters. Just buy self adhesive transparent film and place it wherever you want to change color. Following is just an example of doing it. You can do JDM style amber etc. if you want.
Discussion Starter · #2 ·
Small update on different led color
Ordered some amber led on ebay (5050 SMD Orange) and have some final result to share with you.
One problem that occured right away is - orange/amber color output through blue climate control area turns out garbage... So I gave it a try and modified this area.
I carefully put tape around this area edges and cleaned blue color off with acetone! It worked like a charm and I really like how it turned out at the end.
Discussion Starter · #4 ·
Thanks! I guess there are multiple threads how to do it and I suggest to search them to see where screws are located.
You will have to remove radio with it's bracket to access 3screws holding climate control. You can reach them with short length philips screwdriver or with long one but you will have to remove center console which sits below radio then.
Two nearest screws are @45 degree angle and are tricky, there is one more further at the middle. All screws are accessable from bottom of climate control. Remove cable from heater below glovebox. And it climate control is almost free to come out, there are two wire plugs that need to be detached from back of climate control unit.
