1 - 3 of 3 Posts
wheres my money man!!
This is obd0 ecu plugs.
The white bar has already been removed.
Im using the smallest flat head in the stanley in the set
Basicly you take the flat head put it in the center hole angle in up or down depending on what wire your taking out and push the screw driver in, then pull the wire out from the other side.
this is for both black ecu plugs
the white plug is simpler look in there and youll see a tab use the same screw driver and push it up and pull the wire out
YouTube - How to depin obd0 ecu plugs
obd-1 is pretty much the same
1 - 3 of 3 Posts
