1 - 20 of 29 Posts
Lifetime Awesome Member
'89 CRX HF
Disclaimer: The following is provided as a GUIDE ONLY, and neither myself or d-series.org take any responsibility for the outcomes of someone else doing the following. You follow these steps at your own risk!
ok, well i bought a new cluster out of an SI from mintchoc on here, and i was bored today so i decided to not only put it in, put take pics as i did. plus this section of teh forum hardly gets any attention, so i figured, why not?
Before the swap:
Lets get started!
Tools Required:
Regular phillips screwdriver
Shorty phillips screwdriver
Shorty flat screwdriver
Heres a comparison of clusters, just so you can see the difference. really not much, jus the redline, tach goes to 8, and the warning lights are a little different.
'89 CRX HF
Now start by removing the 2 screws on both side of the hood, on the bottom side
Now, this is the only time you will use the shorty flat SD, remive the cover pieces on the back of the hood, that cover the screws. there are 2 of them
now, i use teh shorty phillips on the back ones, because the regular SD will hit the window and prevent you from getting them out
once these 4 screws are out, the cluster will slide off
pop the rear defrost and dimmer buttons out of the hood(88-89 only)
'89 CRX HF
remove the clips from both buttons, lay these aside
remove the 4 screws, 2 on each side of the cluster, that hold it in place
remove the hood, now you can look behind it. there are 4 things that need to be unplugged. speedo, and 3 clips. the red arrow shows where to push on the speedo cable to remove it
'89 CRX HF
remove the cluster now and this is what you see
set the new cluster in place and install harness
i recommend starting the car and driving it before you put the erst all back together. you dont want to get it all done and see that something doesnt work. once all this has been done, re-install the hood and everything just like you took it off :smile:
Congrats, a new SI cluster in your HF/DX
i had one of those tachs.. just got stolen thursday along with my system and deck...
bye bye 2000 dollars worth of stuff..
good write up tho
'89 CRX HF
mynameistin said:
ryan curious if your gas gauge reaches full when the tank is full and when its on E do you get 10 gallons or so or even more?
on the new cluster? i dont know, just did it today, lol. on the old cluster, no. fill the tank until the gas nozzle clicks, and it is sittin right on the full line. when it is on the empty line, god damnit its empty
10 gallons? haha, i have a 7.5gal tank so i dont think so
D-Series Destruction Master
ryan89crx said:
Cruise Control homie...i think its aftermarket, it was there when i bought the car
not aftermarket, its the 88/89 version, 90/91 put the buttons ON the steering wheel.
Your cruise control controller box is under your fuel filter on the 88/89's, and over the driver side motor mount on the 90/91.
'89 CRX HF
nope, mine is directly behind the intake manifold. plus there were some ghetto wires going from it, over the IM, wrapped arounf the clutch cable, then to the top of the dizzy with a cheap-o wire splice.
random, might have been just the 88/89 LX sedans. Proved me wrong!, its alright tho, cuz i explained how mine was setup on my '88 sedan :)
Nice pic, looks like dirt-o-rama in there, get scrubbin!
CR-Vtakin
your mom
ryan89crx said:
oh ya, i pulled the ricer tach out, i dont need it anymore. i want a more sleeper look and that huge thing kind of ruined it, lol
thank goodness you pulled that thing out! I had one in my car for awhile that the dipshit before me left in the car. I hated it. I replaced my cluster asap with a stock ex cluster. Big tachs in our cars are total rice, only thing worse than one in a car is one that is not hooked up.
Very nice write up, I always like to see mods like this.
lol, true about rice.
I have a 2.5" tach that i was going to use on my '88 civic STD, but instead, i'm going to use my '90 shell that has an SI cluster in it already. So i have a spare tach now...might mount it somewhere hidden...since its supposed to be more accurate than stock...but who knows, might just be BS.
CR-Vtakin
your mom
2.5" is a whole hell of a lot better than a 5" sometimes i think it would be helpful to have a tach hooked up in the engine bay for tuning.
1 - 20 of 29 Posts
