1 - 7 of 7 Posts
D
for those of you that have an irradic idle and are annoyed with it heres how you clean and fix the problem.
IACV = Idle Air Control Valve
step one: locate your IACV it looks like this and on D series engines its mounted on the rear of the intake manifold near the throttle body, and on F series engines its mounuted towards the front of the car on the intake manifold near the throttle body
Step two: remove it, all you need to do is take the 2, 12mm bolts out, disconnect the electrical connection, and your heater lines that run to it. (note put a rag on the heater lines so it doesnt spill everywhere)
Step three: take some brake cleaner or carb cleaner and spray out the screen, which as you can see is very clogged on my 180K+ D15b8.
NOTE you can also take off the bottum part and inspect the gasket to make sure its clean and dirt free, and in my case it was
http://www.superhonda.com/photopost/data/501/42312100-0031_IMG_2.JPG
Step four: Let it dry, then reconnect your electrical connection, your heater lines, and your bolts and BAM your done.
S
Nice post!
Mines been idling at 500-600 for years, so I took the IACV off and cleaned it. It looks good now, but my car still idles at 500-600. I tried adjusting it and still nothing, what the heck?!
C
Good to know. I will try that this evening!
BTW I am new here and from Trinidad!
C
Folks I cant find mine :( . Either its below my Throttle Body(whick is facing sideways like the B series) or somewhere else :?
N
crxtscy said:
good post... i tihnk i'm missing my lil screen... thats probably bad huh?
mine doesnt have a screen either and i cant get the bottom part off.
1 - 7 of 7 Posts
