1 - 18 of 18 Posts
1990 Honda Civic STD
THIS IS MORE OF A REMINDER THAN A DIY.
I was bored this morning at had some Honda Maintenance to do so I change my spark plugs and fuel filter.
Things you'll need:
Fuel Filter
Ratchet
Extension
10mm (Deep)
17mm (short)
Take the pressure out of the fuel system by loosening the fuel cap.
First loosen the 2 fuel lines (Red) carefully not to brake the lines with the 17mm.Put the "flow" line up so fuel doesn't leak.
The carefully bend any hoses your way and take out the 2 bracket bolts (Blue) with the 10mm.
Get open the new fuel filter and washers (4 in total).
Take off the clamping bracket via the 10mm bolt (Yellow). Dump the fuel from the old filter to the new filter if you're cheap like me.:chinese:
Then install in reverse order using the new washers "BOLT-WASHER-LINE-WASHER".
I know a lot of people never change their fuel filter or spark plugs and I can tell you they will hold back your motor quite a bit performance wise and economy wise.
91 CRX Si
I've ran into problems using the copper rings they supply with new filters. Bastards leak! Usually just reused the stock silver colored ones.
formerly allnaturalrex
1989 honda crx si
same thing happened to me i reused the old ones no leak after that.
I replaced my fuel filter not too long ago and no perf or mileage gains. =(
1 - 18 of 18 Posts
