1 - 20 of 44 Posts
S
A buddy on honda-tech allowed me to post this here.
Recently i have been seeing alot of Auto to Manual swap related questions. And lately i have been having alot of people come to me with questions. And this last weekend i did this swap for someone from Las Vegas (SRCivic97 on here). This is in full detail and if you want me to go into more detail let me know and ill be more then happy to answer. I have 146 pics that i took but i had to cut them down to 44 so i could fit them on one thread. But if you want me to post a specific pic let me know. And now, lets begin.
First off the parts list. I could give an rats ass what you heard this is the parts that are needed and what were used and what was not used.
We had:
Car: 1997 Honda Civic EX (Auto)
Tranny: Y8 tranny. Actually you could use any D series Hydro tranny on your D series motor (B series is different obviously but use a Hydro B series tranny)
Clutch Flywheel: Resurfaced stock Flywheel from a 93 DX (was to lazy to send his flywheel off and we had one already resurfaced laying around, totally cool with owner.) But any 92-00 flywheel will work. Clutch we used an Autozone with resurfaced Pressure plate. With an used throw out bearing (just put some oil on it first)
Flywheel/Clutch bolts: Damn im kicking myself for not taking a pic of these. Anyway you need manual flywheel bolts along with clutch bolts. Part #: Flywheel: 90011-PM0-000 Clutch/PP: 90034-P10-A01
Mounts: This is alot of hear say for what to use. This is what you need and why. First off you need an upper tranny BRACKET (not mount) from a 96-00 manual tranny because the auto one doesnt even fit on the tranny, go figure :p (Part #: 50825-S04-000
Next youll need the lower tranny mount off of a manual 96-00 car. Also you will need 3 bolts to go into the tranny as well as 2 that go into the chassis (Part #s: Tranny bolts: 90190-SR3-000 Chassis: 90166-SR3-000
And finally a REAR TRANNY MOUNT Because the auto and manual are totally different. Here is a pic to tell the different. If you use an auto one it wont sit right, although you can use the AUTO bracket on the manual tranny. Part#: 50810-SR3-030
Pedal Assembly: We used a manual pedal (gas to clutch) from a 96-00 manual. But actually all you really need is the clutch one. You could actually keep your auto pedals and just add a clutch one and your set. That way you dont have to worry about pulling the pedals out, which by the way is the hardest part of the swap. You are going to need to get a pin to hold the clutch to the peddle. Part #: 46912-SD4-000
Intake Manifold and Throttle body: You need a y8 manual intake and for throttle body we used an LS throttle body. You could use any manual throttle body, i suggest y8 so you dont have to play with the map. Make sure you get a 2 wire IACV with the intake because if you dont have that you will throw a code and run like ass. We also got a new intake manifold (Y8, use that even if your using a y7 head Part #: 17105-P2F-A02
ECU: Unless your doing something else that involves boost or different setup other then stock you will use a manual y8 ecu (P2P) You could also get a jumper and get a chipped ECU. Most chipped ECU's (if not all) use 2 wire IACV so youll be fine.
Shift Linkage: You need a Dseries manual shift Linkage from 92-00
Clutch Master/Slave Cylinder: Here you absolutly need one from a 96-00 Because the lines are completely different. Now you could probably use these from a 92-95 and just get a SS line and run it straight from the MC to the SC. But if you want the stock look with the hard lines and soft you need 96-00.
VSS: Incase if your tranny doesnt come with one you need a manual one because the auto will not work.
Starter: You need a manual starter along with this one bolt because its longer. Part#: 95701-10100-08
Axles: Use the Auto Axles.
Tools: Basic socket set (Craftsman 256 piece set is great ), a hoist (its ALOT Easier with the motor out), Air if you can (oh man what i wouldnt do without air tools), Prybars (atleast 3 ft to seperate the tranny and motor), Needle Nose plyers, WD-40/PB Blaster, Goop, Quick Steel, and a Dremel. Thats the majority that we used.
Ok Lets begin =)
Pedals!
We got the car kind of late friday night (10/10:30pm, or atleast thats about the time we started) and first thing we did was the interior and pedals. I highly recommend getting this out of the way because the rest is a breeze. So sorry for the pics.
I had the lovely job of taking off the pedals and putting new ones in. Sucks ass i tell you right now. First you want to take off the lower cover of the steering wheel which is held on by 3 or 4 screws. Along with the steering column cover as well which is held on by 2 screws (sorry no pics for this). After that your going to want to drop the steering column. To do that theres 4 bolts (12mm) that you need to take off to do so. I highly suggest having someone help you so it doesnt scare you when it falls. Sorry forgot to take pic, to find these screws look under the steering column and follow until you see a bracket holding it up, take off the 2 screws and itll drop. Once this is dropped its time to strip the pedals.
First lets start off with the Gas pedal and whats attached. In this case we have a throttle cable and Cruise Control Cable.
Well take off the cruise control because its pretty damn easy. Just flip the cable over and push out the pin.
Now for the throttle your going to have to pull towards you then push it out. Theres a small holder for it once you get past the tab its good to go out. (It helps if you have someone holding the throttle body open for you)
S
Lets move over to the brake pedal. Now the brakes are like the gas. This takes a little bit of cursing to get out because your dealing with a cotter pin. Not a problem except for the fact that your kind of blind while your doing it. Pop off the cotter pin then pull out the connecting pin for the Master Cylinder to the pedal.
Now lets move over to where the clutch pedal should be. You should see a big hole with a small hole on each side. Theyll all be plugged. In this case the owner of the car ran wires through his which i had to redo for him. But when you pop those out your ready to put the clutch master through there and put the clutch pedal in. It wont get in the way of the brake and gas while your taking them out and putting them in because you send them the other way.
S
(no pics of the assembly in, but when you have it in theres 2 bolts that attach to the Clutch Cylinder and 1 up in the top.) Now get your pin and cotter pin and put them in and connect them, but dont twist the cotter pin. You dont know if youll need to adjust the clutch pedal yet so incase if you do then its easy to take off.
Now for the brake and gas to take off. For the brake there is 4 bolts that hold on to the master cylinder and 1 up top (kind of like the clutch). When you get those out move over to the gas which is held by 2 bolts (no pics). All the bolts are 12mm. There is also a brake sensor attacted. I suggest taking that off now. The problem with this is that the push is on the top side. What you could do is get a 12mm wrench and twist it so the push is in easy access.
S
Once you get it all stripped off and ready to be pulled have a friend under the hood pulling the master cylinder so you could get the pedals off easier. If your like normal people this is where youll curse alot. Dont worry about it take your time and just tell your friend to pull and pull because more then likely they dont have enough room to bend the lines. Dont rush this cause youll end up with cuts from stupid shit. And put the new in reverse order.
Center Console
I didnt do the center console, SOHC4Life did it, so any questions about this you could ask him. Honestly when i looked at the pics i didnt understand what the hell i was looking at. But my guess is take off every screw/bolt you see =) there is a time you have to go under the car to take out 4 nuts so the auto shifter comes out. I know that because i did it. Disconnect all the plugs and have some one under the car and send the shifter wires to them
When all that is done you could move out to the motor.
Motor!
Most of the regular guys already know how to pull a motor out but for you non knowers todays your lucky day. Here is a quick rundown on how to pull a motor.
First drain all the oil and the coolant. While the coolant and oil is being drained pull the battery and start disconnecting the major connectors on the shock towers and disconnect the starter. I mark and take off the dist because its in the way of the hoist but its not a must. Also there are some coolant lines attached to the transmission. You could take those off with a 17mm socket.
Once everything is drained you could pull the radiator. Becareful because the coolant will still spill a litte. Take off all the heater hoses, fuel hoses, throttle cable, and cruise control vacuum line (if there is one).
Next take off the power steering and AC compressor. Those dont need to be connected. On the PS its 2 12mm bolts holding it on, when thats taken off move it to the side and out of the way. For the AC theres 4 bolts holding it to the mount. Take off those 4 bolts and just let it hang there. Dont worry about it because it wont be in the way and those lines are ment to move.
Now that thats done take off the wheels and start taking off the suspension. You will need a 17mm socket, needle nose, 17mm wrench, and a 1/2 ratchet. Take off the suspension fork with the 17 socket and wrench. When thats off take the needle nose and take off the cotter pin thats under the LCA and then take off the castle nut. Now with that 1/2 inch wrench lift the hub and make room to put the ratchet in there. When its nice a snug kick down on top of the rotor and that ball joint should pop right out. When thats done get the prybar and pull the axle out.
Now move over to the header and disconnect it from the exhaust. While your doing this your buddy should be setting up the hoist. When the hoist is safe take off the 2 19mm bolts from the rear tranny mount, and then get out of there. Go up top and take off the other 19mm bolt and the rear mount is set.
Go to the driver side and on the AC bracket is a mount. Take off the 19mm nut at the end then put a 17mm deep socket and take off the shaft.
S
Take off the rest of the mounts and the motor should pull out with ease. If for some reason it doesnt thats because your attached to something hold the hoist where its at and disconnect what your stuck on. Sorry not to many pics for pulling the motor.
Transmission removal
Now that the motor is out its time to take off the tranny. First however you want to take off the starter. 2 14mm bolts. and you want to disconnect all the wires and sensors attached to the transmission. Honestly you could cut them all except for the VSS if you wanted. Now that the transmission is stripped and ready to go you have about 6 17mm bolts, 2 14mm, and 2 10mm bolts holding the tranny to the block. The 17mms are the big obvious ones (2 up top, 2 on the front (one on each side), 2 on the back). The 2 12mms are next to the oil pan on the stabalizer. And the 2 10s are on the dust cover. When those are off take your prybar and pry the tranny off the block. WARNING! Note that the Torque Converter holds ALOT of tranny fluid in there so be ready. Once that tranny come off tranny fluid will spill. I suggest getting a bucket ready and drain it before you deside to go on.
S
Torque Converter
Now its time to pull this torque converter off. Note that this thing is pretty damn heavy. It has 8 or 10 (cant remember) 10mm bolts on the back of it and you need to rotate the crank to get to each bolts. When all the bolts are off it will just drop, no warning. When the converter is off youll see the flywheel with 6 17mm 12point bolts on it. Take those off and then your ready to put the manual stuff on.
No pics for the manual flywheel. But put on the flywheel bolts like this:
.......1........
....3.....5....
....6.....4....
.......2........
And the torque for these are 87lbs. Do the same with the pressure plate but the torque for those is 18lbs.
Putting the transmission on. Take off the dowel pins from the auto tranny and put them on the manual one. Line it all up and put the new tranny on. 1/2 there now.
Intake Manifold
This is the man reason you want the motor out. You could move around the motor no problem and get to whatever you want. So the intake manifold is the easiest part. Take off all the wiring harness plugs that are attached to the injectors, sensors and all the coolant hoses. If this is your first time i suggest marking everything down so you dont forget where they go. There is 7 12mm bolts and a bracket holding the intake manifold on. Take those off and the intake is ready go come off. When its off make sure there is NO gasket on the head so you could have a good seal. If you think you might pull the intake manifold off again and want that gasket off with ease spray some WD 40 on it and next time its easy to take off.
When you put the new intake on make sure you go in this order:
.....4...2.....3....5....
..6..........1...........7
For the rewire follow the picture i have below that i took from jdmlyfestyle's thread.
S
Run the coolant lines the same way back and your set.
Clutch lines This is pretty easy run the lines. Theres hard and soft but they only go one way Sorry no pics.
Wind Plate!
Now you have the path that the auto cables go through and you probably test fitted your shift linkage up to it and was like "what the hell this thing is in the way" well thats correct it is. What to do is cut it out with your dremmel. You have 2 choices, 1. make a plate or 2 drive with a big hole, and lost of road nose and exhaust heat.
There is going to be a heat shield in the way, take off that heat shield and if you want to do what i did your going to cut a piece of that for your plate. Cut your hole as close to the chassis as you can. The smoother the better. Grind down the paint a little so the harden stuff can stick better. Also grind down the plate so it sticks good, but do both sides of it. Now when you got it nice and clean put your Goop on the bottom and press it up to the chassis until it settles. When it settles take your Quick Steel and spread it all around and get all the gaps. and let it harden and then your set, no road heat =)
S
Wiring!
Now this is pretty easy, but then again i love electrical. But all you need to do is connect 5 wires total. One of the plugs that you disconnected from the auto shifter is a 14P plug. Cut the plug off. Your going to have a 2 thick blk wires and 1 blk/blu wire, Solder those 3 together. Those together lets your car think its in park and releases the key and starts your car. Important ;-)
Next there is a yel/red wire and a grn/blk wire. Doesnt matter what way they go they do the same. These are for your reverse lights. Connect some line to them and run it through the firewall to your reverse light switch. And your set.
Sadly i couldnt figure out the Cruise control but i believe because the car thinks its in park to get the key and start it wont allow you cruise control. But if you want to know your Cruise control wire its a pink wire. Also there is no how to (atleast from me) about wiring a clutch safty switch.
Hope this how to helps alot of you guys. Sorry theres not more pics but like i said i thought these were the most important. If you need more let me know.
Total Work Time: about 8 to 10 hours.
awesome writeup...
just a tip on soldering wires together: if you make a loop with the two ends of wire and loop them together, when you twist the wires together, there's no chance of them coming apart even before you solder them together
S
guest said:
About total cost?
If you do it by yourself, it'll cost around $600 or so. Probably less, depends on where you get your parts. I bought most of mine brand new from honda so mine cost a bit more. If you have a shop do it, anywhere from $1,500-$2,000
makku said:
awesome writeup...
Thanks man.
That's a great tip also. I don't like to touch wiring though. I usually have my buddy do it for me.
Shackle me NOT!!!
1995 Honda Ballade
nice write up, there was nothing around when I did my swap and so me and a mate had to do a lot of research......good shit.:TU:
97 EX Civic
Is it only me
Is it only me cause Im not seeing the pics for this swap. and this would be perfect and exactly what I need for my swap if pics were available
Yep, no pics seen =(
1 - 20 of 44 Posts
