Behind the hazard switch is an anchor point/screw. As you can see mine has been ripped out, by my friend who didn’t know any better. He wanted to test his EX cluster and I didn’t know any better than him, so we’re passing the savings on to you! I digress.
Unplug the Hazard switch and use a Phillips screwdriver to remove the screw.
There are two other screws holding the inlay panel in place, above the cluster. Remove those as well.
Now all you need to do is pop it out. It requires a bit of force. I found that going from the right to the left was best. Just be careful as it will crack easily with the force it takes to pop it out. Once it’s relatively free, unplug the clock wire and tilt/rotate the panel up and to the right to remove.
Now remove the cluster. There are two screws on the right...
…and the left.
Once you remove the screws pull the cluster out a little and unplug the connectors. My cluster has three, but your trim might have a different amount. Remove the cluster.
Here is the cluster with the plastic cover popped off and overlays:
It was either silver or white. I was interested in the indiglo until I saw how freaking bright they were. I drive in pitch black areas, so I don't need the strength of three suns to guide me into a ditch. I wanted just the essential stuff to glow, reassuring, steady, and calm-like. Hence the purchase of reverse glow overlays.
According to both of the threads I linked, overlays should go right over the needle without ANY need to remove anything but the two screws on the speedometer and the other two on the tachometer...just to be clear. They were right.
I started with the right overlay at a clockwise angle, with the gas and temp needles pointed as far down as they could go. I chose the gas needle first, and after fitting it over the needle, used the slack to fit the temp needle on and simply rotated to fit.
There are no screws to hold this particular overlay down, which is a bit irritating, but moving on.
(continued next post…)
…and the left.
