1 - 4 of 4 Posts
J
I just got a call form the garage doign my d15b swap into my 88 hatch std....
i had purchased a brand new TD-02U distributor....and he calle dme and said it doesnt bolt up right....he said he'd be able to hook it up but with only one bolt and that he doesnt recommend doing this....i thought that it was supposed to match up perfectly....but then again what do i know...
any help?
-jawz
If I'm correct the dizzy you need is the z6. Since the head has the same cast, I am assuming that the dizzy from the z6 will fit in correctly. You purchased the a6 dizzy which will work but you need to cut into the head so you can line up 2 bolts. the A6 dizzy WILL NOT line up correctly, unless you cut. Hope that helps otherwise you can use the z6 dizzy and go OBDI. Dont forget the cam gear otherwise you might be a tad weetarded. :)
well are you going obd1 or staying non obd??? if you are going obd1 get a z6 dist. if not just use the a6 one.....mines been hanging on with one bolt for a while no trouble.
1 - 4 of 4 Posts
