· I used to be Admin.....
I drive a 97 Civic EX (obd2) with the stock d16y8 in it, but I will soon be swapping to a z6 head/y8 block setup. Here are the questions:
Can I use the dizzy on my y8 right now, with the y8 P2P ECU, with the z6 head? I will be tuning the 11:1 compression motor with a VAFC, so OBD1 isnt an issue right now. Are there any extra parts that I will need to make it work? Also, will there be compatibility issues between the z6 head and cam, and the y8 dizzy?
Thanks.....
-Deck
You will need the Z6/Z1 dizzy to make it bolt up - the bolt pattern is different. Swap internals from your Y8 into a Z6/Z1 housing and you'll be golden.
So, you mean I can use my y8 dizzy, but I need to put it in the z6 housing? I might as well use the entire z6 dizzy and convert to obd1 for future compatibility.
Tangent question: Will the y8 vtec solenoid fit on the z6 head?
G
just use the entire z6 distributor and repinthe connector to fit on your OBD2 harness. z6 and y8 distributors are the same internally
G
Yes, the solenoid and pressure switch is the same on the Y8 and Z6 and possibly the B16 too. I seen some one on ebay selling a solenoid and pressure switch and they claimed that it would if a b or d series engine but I have never tried it.
