Hey i just started doing the DPFI to MPFI swap and as i was removing the IM i noticed the plugs on the old Dist and the SI are different.. i did not get the SI wiring harness i could not find it. anyone know if just hooking those 2 wires from the ECU to the Dist. if it will work with out the clips being connected?? thanks in advanced
the conncetor allows you to remove the dizzy w/out cutting the wires. find a si distributor connector and switch the wires over.
you know how there is 2 plugs for the Dist ? one of the plugs looks like it wont fit at all.
the thing is i dont have a SI wiring harness, My question was if i could just connect the 2 wires from the ECU to the Dist without pluging it in..if that will work.
i hacked a dizzy plug off of a Si harness and chopped the one off of the DX Dizzy and made a homemade jumper.. GL man..
