1 - 4 of 4 Posts
Replacement of the Distributor O-Ring
By: Noel Adams
I know this is a simple thing to do but I'm sure there are a few people out there that dont know how to do it so heres a DIY :)
Tools Needed:
1. 12MM Socket or wrench ( I had to use 13mm, didn’t have a 12 lol)
2. Some type of marking substance (I used a sharpie)
3. Something to remove the old o-ring (look at picture for what I used)
4. Normal tools to remove the negative battery terminal
Replacement Process:
1. Disconnect the battery terminal
2. Mark you distributor with the sharpie like I did.
3. Remove 3 bolts as pictured, slowly pull it off.
4. This was my oil leak
5. Take the hook shaped tool and remove the old o-ring
6. Now Put the new one on and give it a light coat of clean oil
7. Reinstall the distributor and make sure you marks line up.
8. Done.
Next project is going to be some seafoam after seeing how that dizzy looked.
CR-Vtakin
your mom
nice diy, my dist o ring is sitting in my center console. I was going to do this today, but I was not home. I think I will do it sometime this week.
1 - 4 of 4 Posts
