1 - 3 of 3 Posts
crx
i was wonderign if there if the shaft on th edistrivuter only goes onto the cam oen way? the tab on distributer that goes onto the cam seems kinda off center to me as if it is only mae to go in one way. or is my eyes playign tricks on me?
one of the problesm that i had wuith it is thAT teh continuity test for the white wire that is goign to the igniter isnt groudign out the way it describe sit in the test. i seem to have continuity on that wire all the way to the harness on the distribute so im guesing ti isnt gettign to the ecu.
wich wire on the ecu does it go to?
crx
cool. maybe soemone will knwo about the wire problem or coudl it be an ecu problem? i know that theres no tear in the wire at teh distributer plug where it connects to the harness so im guessign its the engine harness or mayeb the ecu?
1 - 3 of 3 Posts
