1 - 3 of 3 Posts
how do take the rotor off i got the Distributor Cap off but how do remove the rotor from a 94 honda civic dx
Honda Civic
theres a screw on the rotor button that unscrews & comes off,
please hold your hand below the distributor,because the screw will most likley fall fast...
you can also get to the screw more easily when its facing the front of the car,
you can have someone look at the rotor & you can crank the car over just by a very little bit,(not even cranking & it will move the rotor to the position that you need it in)
or
you could put it in gear,release the e-brake & pull the car by rocking it,it will also move the rotor button where you need it to be,
hope I helped...
1 - 3 of 3 Posts
