ministry of mayhem!
stickied. thanks, t.!
i found that in my dizzy bearing quest 3 months ago. on OBD1/2 units, the gears are pressed on and mine wouldn't budge.
looks like they did it a bit differently for the obd0 stuff
not at all, i did the d16z5 dizzy overhaul and 4-tooth gear is pressed on and fixed with a tiny pin (kinda, it's a tube) so you get get it off pretty easily.d16z6 shaft is the same, the only thing rly pressed on both shafts is ~20-tooth gear
I got the rollpin free on mine... maybe I'll take another crack at it and take some pictures along the way. I do know the bearing I ordered was the wrong kind
