1 - 20 of 22 Posts
Distributer problem please help on civic ex 96 (updates)
well i got my car like this and there is no problem on my car but this just dosent seem to b the correct piece.. is der such thing a a vtec distributer and non vtec
yes there are v-tec and non v-tec distributors.
The reason is because the solenoid used to send oil pressure on a v-tec is placed in the vicinity of the distributor so the bolt holes have to be altered on a v-tec head to accomodate for the solenoid.
the above just told you. get a y8 or y7 distributor. anything obd2 except hx... just get a y8 one cause u have a y8 one. whats google and ebay for? just eye candy. the search button is an extra feature thats boosts ur knowledge
welll i got a new d16y8 dizzy and it didnt fit. now looking at the head founf the code P08-5 stamped on it. meaning a 94 SI D16z6 5sp head rye. i saw somewer the 96 ex model comes like that is that true??
wheres my money man!!
only way to get a correct fitting dizzy is to get a 92-95 civic ex d16z6. then repin every thing cause the y8 is a one plug dizzy with the crank sensor at the crank it self and the z6 has a 2 plug with the crank sensor inside the dizzy
just wondering if the dizzy has affect on the vtec because of the vtec and non vtec dizzy's?
thankz... dats would set me correct. i read this combo gives u only a 2hp gain oppose to a d16y8 head&block??
0ok well i put my old dizzy back in and it wont start now... im kinda lost here was working be4 i took it off
1 - 20 of 22 Posts
