68 Camaro
well my bikes all painted (pics soon still looksp retty shitty)
well she has this issue, whenever the petcock is turned on it leaks gas outta the carbs
so i pulled the carbs apart and lubed the needles and needle seats ( pulled the needle out, wiped it clean, sprayed it with carb cleaner then Wd40 on the needles and seats.
i ran her for 15 miles hopin i just needed to get some gas through the seats to lube them but it didnt help... it leaks a lot less then before i rebuilt them but it still leaks.
i figured the combo of carb cleaner and wd40 would swell them just a little bit, and the 40 would lube them.
should i have done it differently?
