ok i have this problem my cluster light and hid light dims only at idle but as the rpm climb up all the light become bright.
is my alternator going bad?
also i have a sub in my car,amp alpine m80 and some cheap sub that bang pretty good.
A lot
voltage regulator going bad in the altenator.
x2. 99.9% sure this is your problem, although it would be a good time to clean up your grounds while you are at it.
Also, make sure your battery is healthy. You DO NOT want to install a new alternator and try and charge a drained battery with it. An alternator is designed to maintain a charge, not revive a discharged battey.
