1996 Civic DX
Hi, I plan on building a D16Y7 engine with vitara pistons and eagle rods. I'm shooting for about 225-275whp on a turbo setup. I know that the pistons and rods are a little bit overkill but I don't want to have to worry about my stock internals breaking.
My problem is, I can't figure out which turbocharger to buy. I'm getting a cast iron manifold from GO Autoworks with a T3 flange, but I don't mind making/buying an adapter to use something other than a T3 turbo. I looked into the TD04L-13T but I read that it shouldn't make it past 230whp and will just blow hot air past that. I also heard that most turbos from Volvos and Saabs won't make it to 250whp. I like the idea of pulling a stock turbo from a car but I'm having issues finding one that will match my goals. Obviously there are turbos made by Garrett, Turbonetics, Precision, etc. that would work but I would rather not spend more that $550. I would like something that spools at a pretty decent speed and would like to start building boost around 3k rpm or so. I want to be able to drive around town without making boost if I choose to. Do I have too many preferences to find a turbo that would work?
you have too little google skills. start by learning to read a compressor map. once you learn that, then you can figure out what turbo will suit your needs.....
god forbid you check the stickies in forced induction.
I got a holset he351 on my Vitara build. goal is 400 wheel. Cheap and reliable, lots of diesel guys cook them and still run fine.
T3 50 trim, king of turbos
93 dx + 92 lx
All my research has been on small snails w <200hp potential. Ever thought of going that direction?
2005 Legacy GT
This should be a serious consideration. You'd be surprised how much fun these cars are around the 180 whp mark ... and with a small quick spooling turbo you have a juicy torque curve to boot.
I had a setup, 175whp/175tq, car ran 12s at the strip with slicks, and COOKED tires. I really liked that setup thinking back to it. It was my first boosted Honda setup, and it was pretty quick and stout.
