1 - 4 of 4 Posts
Can i use the p08 ecu on a d15b7, more than likely the car will be dynoed and tuned.
would there be any negative effect being that the ecu is from an 8 valve motor and im going to swap it out for the d15b7 head which has 16 valves.
i already checked and and the b8 and the b7 both have the same piston part num.
as opposed to older 8 valve motors which only have 2 valve reliefs per pistons.
this for a boost project. thank you
agreed... youll have an adverse effect. ill trade you a p06 for that p08!
i dont know why i said i have the p08, i have the p05 from the b8 ,sorry jared
1 - 4 of 4 Posts
