1 - 13 of 13 Posts
Is there any differences in the bottom ends of the y7 and y8? Are the cranks interchangeable? I checked and the bearings are interchangeable. Are the flywheel ends the same size?
:TU:pistons on a y7 have just a little bit more compression. Bout the only difference.
The y7 engine is a 9.4:1 and the y8 is 9.6:1 compression engine. The head volume is smaller in the y8. My y7 pistons are flat top iirc. What's the y8 piston look like?
Oil pans are different as well...one is cast aluminum and the other is your normal metal pan. I belive the oil pickups have to match as well.
dont throw out the out pistons and rods, let me have them I can add them to my collection of honda parts
Oil pans are different but the pickups are not, right now i have a y7 pickup with a y8 oil pan.
this stuff (just like the pistons/rods) doesn't really matter since he will be building it. true the aluminum pan would be slightly better for cooling, but if its boosted its not really going to matter imo.
98 civic
X2
I'm glad I have the y7 pan then. I welded a turbo oil return into it. If it was aluminum, it would have been a pain.
I don't actually have a y8 engine. I'm just searching for parts (crank) and want to know what's interchangeable.
98 civic
:hijacked: there is no diff. head studs need to put a Y8 head on a Y7 block correct? they are just D16 set?
1 - 13 of 13 Posts
