1 - 3 of 3 Posts
Hi guys, my car just started doing this after I changed my BOV and fix a leaking injector seal.
Sometimes when coming to a stop after down shifting the rpms will get really low and just die. It starts right back up with no problem.
It seams this only happens when its warm. My boost gauge is reading 24 vacuum
I used starter fluid and sprayed everywhere I can to check for leak but no luck?
Its probably because your venting to atmosphere.
my other BOV was a Greddy and it had 2 vacuum lines and the one I have now is a knock off Greedy on and it only has one vacuum line.
The real Greddy one I did have, the adjustment thing was stripped out and was sucking in air at idle. for some reason I thought that was bad?
1 - 3 of 3 Posts
