1 - 6 of 6 Posts
Car is EG hatch w/ d16 kny shocks and ground control coil overs.
Car makes a clunking noise from the drivers side wheel area. It only does it when going slow and straight. It's also not consistent. It isn't caused by bumps in the road. Car also has started pulling to the left. Just had alignment done a month ago.
Any ideas? I was leaning towards axle.
92dx-turbo 92cx-pimp
yeah clicks are usually the axles especially when turning also is there play in the coils are they not slack adjusted? that could be another. pulling could also be allignment or a bad balljoint
It just started doing it a week ago so I don't think it's the coilovers. It's not happening when the wheel is turned. It's not a constant click click click. It's almost like a bigger diameter if that makes sense
reach in there and wiggle stuff, it'll give you a better idea, like the axle and tierod if there tight jack up that side of the car and wiggle the wheel, that'll let you know if its a wheel bearing or balljoint and also wiggle the tierod and axle
cv joint
1 - 6 of 6 Posts
