ok so as some of u know i am tunning noob, i finally got stuff running and i tune each time i drive
my arfs are arond 11.3-.6 with this under boost....still working on it, just wanted a few ppl to look at it and give me any advise or makesure it looks o k. thanks
turn vtec off in your editor. now tune the boost portion of the map well above where you are going to have vtec engage. get it pretty close to where you want your AFRs
now enable vtec, but make it activate at like 3000rpm. tune your vtec map all the way to redline pretty close to where you want your actual AFRs.
now set vtec to the stock engagement rpm and do a pull. if you are on a dyno, there will be a decent dip in power once vtec engages. tune your high cam map at that point, adding or pulling fuel until the dip is as close to smooth as you can get.
