1 - 20 of 27 Posts
How do you determine minimum piston face-to-cylinder head quench pad distance at static state, for dynamic use? I like for the pistons to "kiss" the head when at max RPM. I've only ever done builds by conservative suggestions.
hey idk man, but dont push it to hard or the piston and the head are gonna start having sex if you know what i mean.
racist-bigot-sexist-homophob
clay the motor
it's a NASCAR engine build practice iirc.
Been thinking on doing a Y8 build with PM3 (30.7mm c.h.) pistons lately (with reworked valve reliefs of course).
That's roughly .026" on the negative / above deck.
Put a gasket somewhere in the .075"s to get a .048" p/h clearance for rod stretch.. then i'd expect lips to lips.
This is all just visuals and math as far as I'm concerned. It's all hypothetical so i'm open for comments on it..
Bone, you there?
clay is your friend, then factor in rod stretch.
but also measure how far the piston is sticking up, DO NOT really SOLELY on the compression calcs.
Also I suggest making sure the deck of the block is square before trying to kiss the pistons, the head will need each chamber cc'd to ensure even sizes.
Also note this won't be a good idea for a street motor. That .020" at street rpm = a little carbon buildup, go for max rpms and kiss kiss bang bang, game over.
some pics to look over
R5671A's????? Wait, don't I use them in a Honda?
Is it that the head is re-pinned, and moved? Or that it's re-machined to use a smaller plug? Oh, and I like how he used honda bearings!
Would the manufacturer have the stretch specs? Or is it a "trial and error" knowledge?
Well?
So a BBC shares the same rod journal size with a Honda huh? A realiative of mine competed in that competition last year.
look at the carbon "ring" which is a natural step for anti reversion.
Enlarging the ports like Tony wanted to do would have meant losing the D shaped floor, bigger but likely no increase in flow.
Is that a P29 next to a PM3?
1 - 20 of 27 Posts
