Ok, so as some will know, my car is off being tuned with Hondata. There is a problem though.
When trying to set the map for idle, the car is running at 3k rpm, and is taking on fuel the equivalent of running at 7k. So basically running as rich as fuck!
Initially, cam timing was thought to be out, but this is very unlikely.
The engine is running a big cam, the Bisi level 3. So with that there isnt a lot of vacuum at low RPM's, is that going to cause any issues?
I had the car originally running on a basemap, and it was tough to start, and wouldnt idle. But i was able to hold the revs at 1k rpm, and it would be ok. Just as soon as i let off it would stall. The only thing i have done is changed the injectors to some RC 310 cc, as it was originally running on the Y7 190's!!!
Anyone have any ideas on what could cause this problem....?
