1 - 14 of 14 Posts
99hatch,99coupe,crv
Is anyone running this cam, just wondering of idle quality and street drivabilty vs a bisimoto 2.4 cam just had block done at speedfactory and now getting head done and cam saw the superstreet test seems like the 2.4 should be fine just wondering about delta and heard about gregs new spec web cam, thanks
98 honda civic LX
whats the plans? boost? n/a? if you go on bisi's site he gives a listing for cams and how they run and waht would be good for your motor.
99hatch,99coupe,crv
going boost d16z6 vitara build fj rods, go-autoworks spec turbo, 650 injectors, full-race ram horn, full 3 inch exhaust, s300, skunk2 intake manifold
98 honda civic LX
talk to delta since it sounds like your local. i hear nothing but good news from them
delta cams in tacoma i believe. aslo theres a group by on here right now something like 75 bucks for a reground cam from delta. but you gotta search around on here.
dont waste your money on a cam. you will max out those injectors long before a cam will help you.
99hatch,99coupe,crv
I am puttind id1000 injectors in before i put back together,called delta today and said a 272-2 is very close to the bisimoto 2.4 but is a regrind and there is a groupe buy from d-series. are regrinds ok for long term use or should i get the new cam. talked to greg from go-autoworks about his spec web cam sounds good as well just not sure what to get.
1 - 14 of 14 Posts
