1 - 7 of 7 Posts
hey just a couple questions about swapping this cam into my d15b non-vtec,
would i need to change to aftermarket valves and retainers if i'm only reving to 7000 rpm?
can i use a d16y8 headgasket on my d15b non-vtec?
what camgear to use to correct timing?
Curious George
'99 LX Civic Sedan
Go for 282 with some tuning, get a set of little bit stronger valve spring and retainer, and if you have money and time, 3 angles valve cut, and some heardwork, like porting, polishing and milling.
1988 Honda Civic DX
From what I have heard the Y8 head gasket is the thinnest head gasket Honda makes for a SOHC. This head gasket will raise compression but exactly how much I'm not sure.
1 - 7 of 7 Posts
