1 - 7 of 7 Posts
There's a Del Sol Y7 longblock for sale that I want to get to replace the Y7 in my Civic LX, but I'm a little hesitant because several minor things don't match up.
The crank and piston part numbers are the same, but Honda only lists the Civic longblock for Civic applications. I can't even find a part number for the Del Sol long block.
I just need the internals to be the same as to not upset the stock ECU for emissions. I will be using all Civic accessories and I know they all bolt up. Just looking for info on the internals.
If anyone has experience with the Del Sol Y7, please let me know. Thanks.
you said it yourself, the pistons are the same.
but a birdie named google tells all with the right tickle
Reactions: slo_eg8
del Sol ECU was different on some models, keep the Civic ECU.
Honda got into some trouble over this emissions issue.
Integra DB9
The ECU apart, I don't see why the engine hardware should be different.
Y7 = Y7, surely?
theyre called "civic del sols" for a reason
The two have different p/n's but there is no big difference between them.
Del Sol: 10002-P1Z-A02
Replaces: 10002-P1Z-A01
Civic: 10002-P2E-A05
Replaces: 10002-P2E-A00, 10002-P2E-A03, 10002-P2E-A04, 10002-P2F-A00, 10002-P2F-A01, 10002-P2F-A02, 10002-P2F-A03, 10002-P2F-C00, 10002-P2F-C01, 10002-P2F-C02
1 - 7 of 7 Posts
