1 - 20 of 24 Posts
my buddy is getting a del sol for his chick and they are going to do a motor swap whats the best swap for it either turbo or no turbo they arent sure what they want to do but im thinking this her first build just na would be just fine
any info will help
is the motor blown? does is NEED to be swapped?
D16 will be fun (if boosted) and good on gas...
B16/18 is an easy swap, decently quick n/a...
B20's = fast and CHEAP
H/F are a bit of a pain to swap, but are SICK with a H2D or H2B kit...
K....if you have the money...
I'd personally like to see an R18 swap...
LOTS of variables, mostly depends on what you want out of the car and how much you want to spend...
It would help if we knew whats in it right now. If its for some chick, and its not vtec already, just do a mini me on it.(assuming the bottom end is good) If you want to swap a whole motor, get a complete d16z6. I think a b16 would be overkill for a girl.
he said they are swapping it out no matter what so idk he is new to honda and i have never messed with del sols so ... but money will prob be tight so cheap and buil over time and more then likly turbo so any sugestions
i'd say just drop a z6 in it, but i wouldnt get my hopes up as far as it been quicker cuz del sol's are heavy as f***, ^^^^blueridge did a h22 swap on one, dyno tuned and is still slow as fuck (like 9's in a 1/8), but a z6 is a reliable way to go, and u can turbo it at low boost with minor mods
lol my friends GF is building a B16 for boost they want massive boost so i think a B16 isnt over kill for a girl.
Well?
or an a2 depending on the year. depending on their capabilities, an A6 botom end with either a Y8 or Z6 head would be fairly cheap to do. thats what im doing in mine
think al sol came w/ a3 not a2 .. anyway if the sol alrdy came w/ b16, mite as well stick w/ it...
just swap out only if theres somethign wrong w/ the engine or got a 1.5..
Well?
96-97 came with the a2, 94-95 had a3
Del Sols arent really that heavy.. They're not going to be as light as a cx/vx eg hatch no, but they weigh about as much as an ex of the same year..
and stock for stock sols out handle...the weight is in the right places,
not comparing handeling to a crx, but it has a lower roof line and wider stance than one, along with a hatch.
MODEL 93 S 94 S 95 S 96 S 97 S
Base Price: $15,080 $15,080 $15,080 $? $?
Engine Type/Displacement: SOHC 1493cc SOHC 1493cc SOHC 1493cc SOHC 1590cc SOHC 1590cc
Piston Bore & Stroke (mm): ? x ? ? x ? ? x ? ? x ? ? x ?
Compression Ratio: 9.2:1 9.2:1 9.2:1 9.4:1 9.4:1
Horsepower (hp net) 102 @ 5900 102 @ 5900 102 @ 5900 106 @ 6200 106 @ 6200
Torque (ft-lb) 98 @ 5000 98 @ 5000 98 @ 5000 103 @ 4600 103 @ 4600
Redline 7200 rpm 7200 rpm 7200 rpm 6900 rpm 6900 rpm
Brakes (front/rear) 9.44" Disc/Drum 9.44" Disc/Drum 9.44" Disc/Drum 9.44" Disc/Drum 9.44" Disc/Drum
Wheels 13" w/Covers 13" w/Covers 13" w/Covers 13" w/Covers 13" w/Covers
Tires 175/70R13 82S 175/70R13 82S 175/70R13 82S ? ?
Transmissions 5M / 4A 5M / 4A 5M / 4A 5M / 4A 5M / 4A
Manual / Auto Ratios (1) 3.25 3.25 3.25 3.25 3.25
(2) 1.90 1.90 1.90 1.90 1.90
(3) 1.25 1.25 1.25 1.25 1.25
(4) 0.91 0.91 0.91 0.91 0.91
(5) 0.75 0.75 0.75 0.75 0.75
Final Drive (man/auto) 4.06 / 4.33 4.06 / 4.33 4.06 / 4.33 4.06 / 4.33 4.06 / 4.33
Curb Weight lbs(man/auto) 2,295 / 2,387 2,295 / 2,387 2,295 / 2,387 2,302 / 2,388 2,302 / 2,388
EPA mpg city (man/auto) 35 / 29 35 / 29 35 / 29 33 / 28 33 / 28
EPA mpg highway (man/auto) 41 / 36 41 / 36 41 / 36 39 / 35 39 / 35
0-60 mph (sec) 9.2 9.2 9.2 8.7 8.7
0-80 mph (sec) 16.8 16.8 16.8 15.9 15.9
0-100 mph (sec) 32.5 32.5 32.5 30.1 30.1
1/4 mile (sec) 17.2 17.2 17.2 16.9 16.9
1/4 mile speed (mph) 81.0 81.0 81.0 82.3 82.3
Top speed (mph) 113 113 113 115 115
Braking 60-0 mph (ft) 146 146 146 146 146
Lateral Acceleration (g) 0.81 0.81 0.81 0.81 0.81
MODEL 93 Si 94 Si 95 Si 96 Si 97 Si
Base Price: $17,300 $17,300 $17,300 $17,300 $17,300
Engine Type/Displacement: SOHC 1590cc SOHC 1590cc SOHC 1590cc SOHC 1590cc SOHC 1590cc
Piston Bore & Stroke (mm): 75.0 x 90.0 75.0 x 90.0 75.0 x 90.0 75.0 x 90.0 75.0 x 90.0
Compression Ratio: 9.2:1 9.2:1 9.2:1 9.6:1 9.6:1
Horsepower (hp net) 125 @ 6600 125 @ 6600 125 @ 6600 127 @ 6600 127 @ 6600
Torque (ft-lb) 106 @ 5200 106 @ 5200 106 @ 5200 107 @ 5500 107 @ 5500
Brakes (front/rear) 9.44" Disc/Disc 9.44" Disc/Disc 9.44" Disc/Disc 9.44" Disc/Disc 9.44" Disc/Disc
Wheels 14" Alloy 14" Alloy 14" Alloy 14" Alloy 14" Alloy
Tires 185/60R14 82H 185/60R14 82H 185/60R14 82H 185/60R14 82H 185/60R14 82H
Final Drive (man/auto) 4.25 / 4.33 4.25 / 4.33 4.25 / 4.33 4.25 / 4.33 4.25 / 4.33
Curb Weight lbs(man/auto) 2,414 / 2,474 2,414 / 2,474 2,414 / 2,474 2,414 / 2,474 2,414 / 2,474
EPA mpg city (man/auto) 29 / 26 29 / 26 29 / 26 30 / 28 30 / 28
EPA mpg highway (man/auto) 35 / 34 35 / 34 35 / 34 36 / 35 36 / 35
0-60 mph (sec) 8.2 8.2 8.2 8.3 8.3
0-80 mph (sec) 14.8 14.8 14.8 15.1 15.1
0-100 mph (sec) 26.5 26.5 26.5 27.1 27.1
1/4 mile (sec) 16.6 16.6 16.6 16.7 16.7
1/4 mile speed (mph) 84.9 84.9 84.9 84.5 84.5
Top speed (mph) 122 122 122 123 123
Braking 60-0 mph (ft) 126 126 126 124 124
Lateral Acceleration (g) 0.84 0.84 0.84 0.87 0.87
MODEL 94 VTEC 95 VTEC 96 VTEC 97 VTEC
Base Price: $19,600 $19,600 $19,600 $19,600
Engine Type/Displacement: DOHC 1595cc DOHC 1595cc DOHC 1595cc DOHC 1595cc
Piston Bore & Stroke (mm): 81.0 x 77.5 81.0 x 77.5 81.0 x 77.5 81.0 x 77.5
Compression Ratio: 10.2:1 10.2:1 10.2:1 10.2:1
Horsepower (hp net) 160 @ 7600 160 @ 7600 160 @ 7600 160 @ 7600
Torque (ft-lb) 111 @ 7000 111 @ 7000 111 @ 7000 111 @ 7000
Redline 8200 rpm 8200 rpm 8000 rpm 8000 rpm
Brakes (front/rear) 10.44" Disc/Disc 10.44" Disc/Disc 10.44" Disc/Disc 10.44" Disc/Disc
Tires 195/60VR14 195/60VR14 195/60VR14 195/60VR14
Transmissions 5M / (n/a) 5M / (n/a) 5M / (n/a) 5M / (n/a)
Manual / Auto Ratios (1) 3.31 3.31 3.31 3.31
(2) 2.11 2.11 2.11 2.11
(3) 1.46 1.46 1.46 1.46
(4) 1.11 1.11 1.11 1.11
(5) 0.85 0.85 0.85 0.85
Final Drive (man/auto) 4.40 / (n/a)
Curb Weight lbs(man/auto) 2,491 / (n/a) 2,522 / (n/a) 2,522 / (n/a) 2,522 / (n/a)
EPA mpg city (man/auto) 26 / (n/a) 26 / (n/a) 26 / (n/a) 26 / (n/a)
EPA mpg highway (man/auto) 30 / (n/a) 30 / (n/a) 30 / (n/a) 30 / (n/a)
0-60 mph (sec) 7.0 7.0 7.0 7.0
0-80 mph (sec) 12.2 12.2 12.2 12.2
0-100 mph (sec) 20.3 20.3 20.3 20.3
1/4 mile (sec) 15.7 15.7 15.7 15.7
1/4 mile speed (mph) 84.5 89.1 89.1 89.1
Top speed (mph) 131 131 131 131
Braking 60-0 mph (ft) 124 124 124 124
Lateral Acceleration (g) 0.87 0.87 0.87 0.87
1 - 20 of 24 Posts
