1 - 11 of 11 Posts
hy i cant decide between the bullseye 252 or the 259 both of them with the batmowheel...
looking for a quick spool up and hit the 350-400hp goal.
heres my setup:
z6 bottom end
75.5 vitara/custom rod combo around 8.5cr
mild ported head
supertech springs/retainers
delta 272-2
id1000
walbro intank+inline
mild ported IM stock TB
tuned on neptune with e85
thanks for the input!
Id say 252 for spool time.
Go for the smaller one so that you have more usable power.
And that wheel is expensive, in my opinion it is not needed.
Your setup looks pretty similar to mine, and I went with this Bullseye 55 trim turbo :
You'll easily meet your goals with a decent spool out of it too.
the normal 252 is rated at 450hp and with the new wheel 550hp...
more opinions?
i think it will be a lotta fun to drive with the spool characteristic!
Ah then It's a no braier man get the 252 it'll have a much better spool time and you still have plenty room left if you decide to up the boost in the future.
could go s256 with batmowheel from greg at go-auto.. would let you take it all the way to ~475hp and is said to outspool garret gt4036r.. (don't really know what rpm that is though)
or the s252 works too... would be better spool..
1 - 11 of 11 Posts
