I have a 94 civic hatch with a d16z6 swap (auto to manual conversion) I purchased 94 up integra front spindles/brakes. I replaced the lower ball joints and replaced the wheel bearings and studs (also swaped the brake master and booster from the same integra). my question is what axles do I used because I have new d-series axles and it doesn't seem to be seating properly, I can not get the axle nut to tighten flush and this is on both sides or could I be am using the wrong hub (using the hubs from the integra)? any help would be greatly appreciated....
Love the Civic
Got this from a thread by searching, because I couldn't remember my self.....
ALL 94-01 Integra's w/ABS including Type-R use knuckle p/n's 51210-SR3-N10 and 51215-SR3-N10. These are the same p/n's for 92-95 Civic's w/ABS(some models in 94-95 had ABS parts without ABS). For the Integra RS and Civic Ex w/o ABS the knuckle p/n's are 51210-SR3-N00 and 51215-SR3-N00, these are physically the same as size and shape as the other knuckles just without the holes drilled for the ABS speed sensor.
For a good upgrade for the rear use 02-06 Civic Si(EP3) caliper bracket mounts, 02-05 EP3/RSX brake pads, stock Civic/Integra rear calipers, and 02-05 EP3 rear rotors.
Don't think it is the knuckles themselves. Bearings installed correctly?
I had a shop press the bearing for me. it like the part of the axle that goes threw the hub is like a 1/4 inch short. ill post a picture when I get off work, since I am unable to drive the car right now.
I have the same set up and had no problems. Pics might help us help you.
Love the Civic
Make sure you get the back of the hub too.
Are you sure it is a 92-95 set of axles and not 88-91? Those are shorter. Let us know homie.
