OK
In the ongoing saga of my son's 92 civic-
It was parked for awhile in the city-someone smashed the window and ripped the Head unit out. They actually broke the side mirror off and used it to break the window. These have been repaired.
now I have bare wires-no clue where they go, and a broken surround trim.
I acquired the new trim part. It seems the entire dash need to be removed to swap it-
also-the hazard light button will not stay put-
I'm reaching out for tips. Thanks!!
lets see if i can help ...
Are they wires that were for the radio?
right rear spkr + red/w yellow stripe
left right + blue/w yellow stripe
+12 volt yellow w/red stripe
right rear - brown w/white stripe
left rear - gray w/white stripe
Ground Black
+12 volt battery white w/yellow or blue
left front spkr + blue w/green stripe
right front spkr+ red w/ green stripe
left front spkr - gray w/black stripe
right front spkr - brown w/ black stripe
You might even have a cigaret lighter wire there somewere
and the hazzard light button thing just means you need a new button
Good luck if you need any more help pm me
So,
Am I correct in assuming the entire dash needs to come out to replace the stereo-heater control-steering wheel surround thingy?
I belive it just unbolts and pulls off
its been a while lol
Well here is what I have to work with--fukkin thieves--
I replaced the heater control panel-working on stereo wiring right now-
I am confused--what are you referring to when you say left right?--second wire label -the blue with yellow stripe-
Ground Black
FAMILY MEMBER #316
i believe he meant left rear
