1 - 2 of 2 Posts
ej2
So I'm installing my Koni Yellow's and I find out the damper fork is too small for them?
They fit my agx's perfectly.
Is there an easy method to make the damper hole bigger?
Edit: After further research, I find that I have EF/DA forks (WTF!)
Im not familiar with an AR/AL. The EF/DA fork is a HR/HL. EG/DC fork (same height, larger diameter) is a VR/VL.
I have no idea what AR/AL are from.
A small chisel driven carefully between the pinch tabs works.
When installed my Konis I ran into the same thing. Took some persuasion with a blind object but got them in there. Getting them to fit with the brake line bracket was a whole nother saga.. :)
Edit: sorry I posted this before I read the note about the incorrect forks
1 - 2 of 2 Posts
